Are you looking for something like this?
Guan Yin Statue (Standard Quality) by Aerial 3D360 - download 3D model
The statue is shot by FPV Camera app, then processed by a cloud service.Is that one of your projects?
What is it that sets it apart?Unlike other capture apps for mapping, FPV Camera uses a very different way for optimizing 3D model capture.
Traditional 3D mapping capture approach wouldn't work well on 3D model, especially for tall object such as a tall building or statue. Worth to read more 3D Model
I prefer to use Altizure, after you upload the images they process them very quickly and you can create flyovers etc.
I also like dronedeploy because you can edit the boundaries of your map, the map can be ovelayed on top of a google map and you can measure distance and area (the total size of your map is measured automatically in acres).
You could also use Pix4D if you want to process the images yourself but unless you have a very nice computer it will likely take a lot longer(this is the reason I only tried Pix4D once)
Although each method has it's own capture software, I use the Altizure app for all of them. The altizure app does not have problems with altitude data so you don't have to use ExifTool. The pictures captured with the Altizure app are compatible with all the methods I previously discussed.
Hobby, my dad wanted his mountain property mapped and I was more than happy to oblige. I have mapped a few other things since but not much.That's great info, thanks for posting it. Do you do 3D mapping professionally or as a hobby?
Hi does anybody use their Phantom 4 for photo's to create 3D models. If yes, I would be interested to find out what software you may be usings and its pros and cons. Thanks in advance Flywest.
HelloI recently started using Spotscale, they've been delivering super good quality of their 3D models compared to Drone Deploy in my opinion. It's a cloud based service, you just need to upload your images and you'll get your final 3D result delivered after they process it. I can highly recommend them, worth a try!
