32 channel hack
Discussion in 'Pro/Adv Discussion' started by Moonie, Feb 25, 2016.
  1. Moonie
    I been trying to get the 32 channel hack but it's not working for me. I have a iPhone 6 and a iPad Air. I down loaded thefile, unzipped, and added it to my Dji go app in iTunes. Can anyone help me out here I'd like to try this out.
  2. fordruid
    Wisconsin
    Set app for manual (or custom?) instead of automatic channels?
  3. ringolong
    TN
    Are you sure you added it? Did you get a replace the file when you added it?
    What fordruid said too.
  4. Oso
    Oso
    Western US
    Follow these steps carefully and it should work with no issue.
    More channels hack
  5. Moonie
    I used custom channel select. First time I tryed it didn't replace the second time I tryed it replaced and still didn't work. I used my Mac and it didn't replace but it added a new file but sill not working.
  6. ringolong
    TN
    Have you restarted the app since replacing?
  7. yakangler10
    It's because your using a Mac. I had this problem at first until i tried it on my windows computer.
    You cannot have a file that starts with a . on a mac because they are reserved for system files. So the file your copying isn't the correct file name. The file name should be something like .dji.config and that is not allowed on a Mac.
    Switch to a PC and it will work. Good luck
  8. ringolong
    TN
    Worked fine when I used my mac, and have done this many times. o_O
  9. yakangler10
    using a 2011 macbook pro running OS el capitain.
  10. ringolong
    TN
    Ok. You may be onto something. I stand corrected.
    I have the actual file stored on my windows 2012 server, and just drag and drop from that folder.
  11. Moonie
    I just did a restart and still no luck.
    That's the file I down loaded. Dji config.
    Did I mess up by putting both fies PC and Mac? It didn't replace when I tryed the Mac download after the PC download.
  12. yakangler10
    I would delete what you have and re-download the file on your windows pc. extract the file and than drag and drop into itunes and it should work. That's how I did it and it worked for me. As mentioned above make sure in the DJI Go app that you click custom when looking at channels.
  13. Moonie
    Do I have to unzip it on PC?
  14. ringolong
    TN
  15. Oso
    Oso
    Western US
    Are you following the step by step instructions I gave you?
  16. Moonie
    Yes step by step. I just saw that I can not on zip my files on my PC. I have to get some new software before I can open it. I can unzip on my iMac and it shows up. It's a older iMac maybe that's my problem with that. Im going to delete the old files and start over with the Mac because it's free rite now if it don't work I'll get the new software for the PC.
  17. Alexlapo
    Cheshire UK
    If you are from the UK the DJI go app won't let you change to custom so you have to change your device to US in the settings
  18. Oso
    Oso
    Western US
    That's correct.
  19. Alexlapo
    Cheshire UK
    I had this problem, this advantage for me will be brilliant (I hope) because where I live I have lots and lots of interference can't even take my bird to 50 feet without loosing live video feed! It all works fine for me but what I don't understand is the channels, is the lower the better and also is it mainly channels 25 onwards you choose from?
  20. Oso
    Oso
    Western US
    Its not necessarily lower or higher is better. It's just channels that seem to be quiet in comparison to the others. In my particular case, it does tend to be the higher channels that are quieter. Even so, I rarely ever use the extended channels anyway. Some others of course may need them more often if they are in a very noisy area.
Similar Threads - channel hack Forum Date
32 Channel Hack working? Phantom 4 Discussion Jul 28, 2017
32 channel hack Phantom 4 Discussion Jul 13, 2017
Does the 32 channel "hack" work on the p4a? Phantom 4 Pro Discussion Jul 12, 2017
DJI Go4 and 32 channel hack Phantom 4 Discussion Jun 29, 2017
DJI go 4 channel hack? Phantom 4 Help Apr 10, 2017
