3 flights since back from DJI for cracks repair
Discussion in 'Pro/Adv Discussion' started by Zoti, Dec 30, 2015.
  1. Zoti
    And it's already cracking. Not that I thought it won't but give me a break. ImageUploadedByPhantomPilots1451454423.000759.jpg
  2. alokbhargava
    San Francisco, CA
    You got bad luck. Sorry.
  3. mmee1992
    Can you tell if you have the reinforced shell?
  4. Zoti
    Not reinforced shell.
  5. Tom Connell
    Valdosta, GA
    Medium Zap glue and Zap Kicker are your friend. I know nothing about the insides, but would take a small patch of fiberglass on the underside of the crack, scuff plastics under crack area and mix up some 6 min epoxy and saturate the patch. Press out the excess with popcicle stick. Let dry. Crack will not expand.
    I'll know more by weekend when my Phantom 1 comes in.
  6. mirrorimage
    Palo Alto, California
    Stop sending them to DJI for repair. It's a waste of months of time. Buy a new shell on Amazon for $76. Do it yourself and you can literally have it done by end of day tomorrow. I know it's not fair but it still better than waiting on DJI
    mmee1992 likes this.
  7. JamesBandes
    Why can't DJI fix the issue? I heard on early models the screws were tightened too much. Loosening them just a touch supposedly fixed the issue
  8. KMD1984
    Because it's DJI...
  9. 847guy
    chicago
    mine took 2 1/2 weeks, from the time i contacted them to the time i got it back
  10. mmee1992
    I did exactly that. Just make sure you get the redesigned shell.
  11. Zoti
    DJI have issued another RMA.
  12. andy antoniou
  13. Zoti
    And back to DJI for repair it goes.
  14. With The Birds
    Australia
    Id send dji photos and ask for them to ship a new shell at their cost..... that is ridiculous. They come out with a new shell design and still give you the old version in the repair. They wouldnt have gone to the tooling and other expense of implementing the production chamge if it wasnt an attempt to correct a known issue.
  15. Zoti
    Let's see what comes back. They paid shipping.
  16. With The Birds
    Australia
    Zoti just looking at the pic again Mate- could it have anything to do with the torque on the screws when tightening? Its still likley a design flaw regardless.
  17. Zoti
    The crack wasn't there when I got it back last time. And I could care less why it's there. I want it repaired. The shell bottom they installed last time was same as the original one.
  18. Richard W
    East Coast, USA and CANADA
    Before you start flying again, put one of these 6- or 4-screw enforcers under each motor. If you like guards, get a snap on set with, again 6- or 4- screw, base. They will keep it together by taking some load off the shell and distributing it onto themselves.
    IFAIKT, the original DJI 2-screw guards can make things worse by actually adding the load to the end of shell where it is most vulnerable and obviously underweighted.
  19. Zoti
    I had reinforcement plates installed on the original shell. Didn't help one bit.
  20. Richard W
    Sorry to hear ... must be a really weak design then, or not well fitted motor mounts.
Similar Threads - flights since DJI Forum Date
"Map Loading" on all flights since August 3 Pro/Adv Discussion Oct 11, 2015
Testing in GPS for P3. Since May, with daily flights I'm testing in professional GPS on my P3 Pro/Adv Discussion Jul 31, 2015
Couldn't use Litchi last 3 flights, Go worked perfectly...? Control (Go, Litchi, etc..) Tuesday at 9:56 PM
How Many Flights on Your Phantom 4? Phantom 4 Discussion Aug 9, 2017
Syncing flights Standard/4k Discussion Jul 27, 2017
