- Joined
- Mar 29, 2016
- Messages
- 14
- Reaction score
- 1
- Age
- 39
I understand the dji props are by far the best efficiency for the phantom. But i was wondering if the 3-blade props might do better in the lower pressure air?
Nope. Some say that at a certain RPM, the additional prop(s) will slip into its own stream and it may be less efficient (less grip of air). Think of boat propellers that spin way too fast and create white wash (air pockets). If too much white wash, then you wont produce effective thrust.
Increasing the diameter of the prop may help, but could hinder weight as they may require larger motors.
Im going up far west in the rockies. Redstone Co, its an hour west of Aspen.Not sure if this will make any difference in your question but just so you know normal barometric pressure at sea level is around 29.92 " of Mercury or 14.7 psi. In contrast, the barometric pressure in say Denver is 24.63" of Mercury or 12.1 psi. So what does all that tell you. When it comes to flying your drone it means very little. You have to remember the amount of surface area that you're dealing with. If the service area is negligible then the affect will be negligible! Hope this helps
