- Joined
- Feb 25, 2014
- Messages
- 162
- Reaction score
- 0
Mori55 said:Haven't heard of 3.05 ? We're did you hear about it ?
midwestjeff said:I have been following the Beta testing of this update and so far so good! We should see some improvements on many fronts if DJI approves this update as is. Stability of descent without slowing the quad down to 2 m/s is looking promising.
rrhansen said:Not sure if this is related...but maybe?
Just got replacement P2V+ and have about 6 small flights (4 batteries worth) and find that with 6 satellites, it wanders much more than my P2V used to. My old P2V (before the first P2V+ that was just replaced) was solid as a rock - would hold position in GPS mode very well regardless of # of sats (6 or more) - maybe 3-5' in any direction max. The new one wanders 10-25' in any direction...like it's hunting for signal or something. It eventually seems to settle down...but disconcerting to go very far with such apparent 'lost' behavior.
Running 3.04 and NAZA has been enabled, but am in full GPS mode. In ATTI, it stops wandering, but obviously prone to wind issues. Back in GPS mode, just got 8, and then 9 sats a moment ago - much less wander - seemed 'happier' with the added sat's. I did do an advance compass calibration and it seems to be within parameters ( +/- 300, and 1400-1550 mod).
Any suggestions?? Also noticed that in Course Lock, it doesn't fly straight-away...have to make stick corrections to keep it running true from me. Is this a related issue to the 3.04 problem?
obiwan_pierogi said:rrhansen said:Not sure if this is related...but maybe?
This is why we're all patiently waiting the upgrade.. You'll find after about 4 minutes of flying, your phv2+ does better.. Mine is like that.. As soon as I lift off, it goes into circles (toilet bowl effect), as if trying to get its berrings.. Find out your magnetic declination.. Do a google search.. If you're positive like I am (17.3+), the circles will be counter-clockwise, as viewed from the top/.. You'll also find a drift to the left, after a straight run.. Be careful.. It's a good way to crash your copter, especially if the wind is blowing..
sar104 said:midwestjeff said:I have been following the Beta testing of this update and so far so good! We should see some improvements on many fronts if DJI approves this update as is. Stability of descent without slowing the quad down to 2 m/s is looking promising.
Could you elaborate on the descent limits comment? I'm one of the beta testers for 3.05, and I'm completely unaware that it included any changes in that respect. Additionally, I don't think the existing beta is heading for release - last I heard we were expecting another beta version.
midwestjeff said:Yes, there has been changes in the descent algorithm to minimize the "wobble" experienced in Firmware 3.0 with the 3 m/s rate that caused some users to experience "prop wash" crashes. Now many people would love an even faster descent rate of say firmware 1.08, but that will never happen.
flyNfrank said:I received my new vPlus around 3 weeks ago and noticed it wanted hook left. I then found it got worse after installing my Flytrex hardware on the landing gear leg left of the battery. I figured out that I had covered up the antenna wire with the wiring from the flytrex device. So I completely rerouted the antenna wire from where it starts on the board. It had been looped though other wires and I just made it route as clean as possible and back out through to the same leg again. I then re calibrated the compass, and it now flies straight every time.
One thing is for sure, I didn't buy my copter to sit around in grief to wait on dji for several months. I'll try to fix it myself if possible.
