2 transmitters 1 gopro one wth and 1 withot telementry
I have a Phantom 2 with a Zenmuse 3d gimbal, gopro3+, avl58 transmitter receiver,mini iosd. I view it with a standard receiver monitor. the gimbal, mini iosd, transmitter are connected thru the phantom 2 hub board. I would like to keep the iosd telemetry on the receiver monitor and receive just the gopro video thru the avl58 receiver. is there a way to do this?
You would need to find a way to split the video signal off, between the Phantom's mainboard and the hub somewhere. The forked video would then have to be fed to an AVL58 transmitter (i.e. the one you have) for it to transmit to your AVL58 Rx free of iOSD data. The main video feed from the hub would go to whatever Tx you wanted to use that's compatible with your monitor, so you can see the gopro's video plus the iOSD data on that.
In short, yes you would need two transmitters on the Phantom.
that's what I was thinking I just wanted to hear it from someone else. I think its the white and black coming from the gopro I need to split. thank you
jrl
