1st Waypoint of multiple waypoint mission Problem
Discussion in 'Phantom 2 Vision + Discussion' started by kookjo, Mar 6, 2015.
  1. kookjo
    When I use the waypoints everything works fine, with the "Fast" mode was faster but no big issue. The one problem I have is at the 1st waypoint. My PV2+ turns as it should towards waypoint 2 then it turns back pointing in the original direction then turns back to waypoint 2. Never has happened with any other waypoints.
    Just looking to understand if this was happening to anyone else and if you had a fix.
    Regards,
    Brad
  2. eseckinger
    It is a known issue. Try to make the turns a little less than 90 Degrees/More subtle and often it will not do this.
  3. ccase39
    Yea it just happens. I think when its 90 degrees or greater is when it happens.
Similar Threads - 1st Waypoint multiple Forum Date
1st waypoint 3000ft away Control (Go, Litchi, etc..) Jul 12, 2017
Phantom 4 gets stuck at 1st waypoint and just hovers Phantom 4 Help Nov 9, 2016
Litchi initiated RTH instead of Go to 1st Waypoint. Standard/4k Discussion Sep 14, 2016
My 1st P3S night video Photos and Video Aug 7, 2017
1st attempt at Tiny Planet Photography (P4) Photos and Video Aug 5, 2017
