$18 for 2200mah 11.1v 30c w/ consistently good reviews??
I know some one who only would buy high end batteries for his helicopters and tried the MotionRC batteries and put them to the test. I can say this!!!. He no longer is going to spend the money for the high end batterys. Also if you do the math on the C rating and you are using 30C your Phantom will never draw that many amps. So here to all is the real calculations. Take 2200 mah = 22 x the 30c rating and you get 66. 66 is the constant amp draw that the battery will give. Just st let all know I am not looking to start a debate on this. After 23 years in the electronic industry this is the math a major automotive battery manufacture uses. The higher the c rating will not give you longer flight time unless you are using the calculated amps. It will allow you to charge the battery faster. The higher the mah the longer the flight time. This is just food for thought.
BoguSlav
