I see both links.
12 miles in CE mode? Pretty darn good.
An RC mode in europe where the RC power is disabled by about 75% and the range is therefore disabled by about 50%...
Search Results for Query: ce mode | DJI Phantom Drone Forum
not loading for me mate :-(
Hi; I've now got a Phantom 4 - can you tell me how you 'record' the video and then the 'map telemetry' together? I can record my videos to the micro-SD but am unsure how you record the map view - is there a download from within the telemetry data or do you just go to map mode when you're recording? I'm darned if I can find the answer on the DJI website...Just seen this - sorry if you have seen this already... a massive UK flight
Awesome! I get the shakes flying over a pond!Just seen this - sorry if you have seen this already... a massive UK flight
That was very impressive i hope to be able to have the guts one day to try that.Just seen this - sorry if you have seen this already... a massive UK flight
The Dji Go app does not record Telemetry, as far as I know, ..I use Litchi app to record screen.Hi
You are correct, the 300C sucks for transmitting power. I've measured the RF transmit power and compared it to 300A and the Inspire 658A. The 300C is the weakest lightbridge RC DJI has ever made. This is one of my disappointments with the P4. I use the Inspire RC with the P4 as a result.Allegedly.
I get 3 miles out totally standard!!!
That is with a P3P on a 300B controller.
I think poor range is caused by the 300C.
He upgraded his drone range extenders, I would take the risk doing it.Just seen this - sorry if you have seen this already... a massive UK flight
It's nice that you have had good luck. With the P4 RC I constantly get control signal disconnects just 3000-4000ft away, where I NEVER get control disconnects with my P3P (300A) even at 12,000ft away. It's a night and day difference in my case, very disappointing. So, I've mothballed my P4 RC GL300C and use an Inspire GL658A with my P4. With that my P4 performs like my P3P from a range and signal integrity point of view, like it should in the first place IMHO. There is no doubt in my mind that DJI is reducing power, hence less range and signal connection strength. My signal strength measurements prove the trend. We seriously need some competition for DJI so they stop this power reduction strategy. So far only Autel seems to be close. I expect the value of old DJI Lightbridge RCs is going to skyrocket if this keeps going on.I think all this about power between the A , B and C controllers is just in theory!!
In practice, different story.
I got an A, B and now the C when I got the p4.
I did a test in LOS condition and non LOS using the p4 with the different controllers at the same location, flight path, day and time period.
They all were the same, more or less to a few feet. In LOS condition the limiting range factor was always the battery.
In really bad non LOS, trees and houses directly in front of me within 25', there was no range difference between different controllers either! Around 3500' range
I used to get 10,000 feet range with my 300A
The USB port stopped working. My dealer offered me a new 300C. I said no thanks so they found me a 300B old stock.
My range went from 10,000 losing signal to 14,000ft plus with no loss at all. Battery is now the limit.
Everything standard!!!
