11/25 New Vid Tutorial: DJI PV2 Intro to GPS Flight Control
Discussion in 'Phantom 2 Vision Discussion' started by iDrone, Nov 27, 2013.
  1. iDrone
    Los Angeles, California USA
    Phantom Vision GPS Mode & Return To Home Mode very nicely explained:
    http://youtu.be/Lsp-w7361dQ
    Couple of interesting features:
    - If you're higher than 20m, the Autopilot will maintain that altitude flying back.
    - Return to Home airspeed is approx 15mph.
    - PV will hover 15 secs over home before its descent in case you want to takeover.
    iDrone
  2. gpauk
    Aberdeenshire, Scotland
    Re: 11/25 New Vid Tutorial: DJI PV2 Intro to GPS Flight Cont
    Yep.. Handy video...
    He didn't say, but I would assume you can cancel the RTH at anytime by flipping out of GPS into ATTI mode, same as a P1.
    It would be useful I think if it beeped regularly while in RTH. That would both warn people below, and provide another way to realise that it was in RTH, in case it gets there without you realising....
    Looks like his video was running out of range at 450 feet too!
  3. gunslinger
    gunslinger Moderator
    Staff Member
    Least Coast...
    Once you regain control in ATTI mode, can you then switch it back to GPS mode?
    -slinger
  4. Pull_Up
    South Oxfordshire, UK
    Yes. Or indeed simply flick it down and straight back up again to regain control and resume GPS mode.
  5. TisiRaptor
    I have tested this, so that I could be confident that it would work when needed. Yes, If you switch the controller off it goes to RTH mode and then all you need to do is switch it back on, flick the S1 (or S2, depending on how you're set up) to ATTI to regain control of the PV. Equally, you can then just switch back to full GPS (position 1 on S1).
    Incidentally, you can configure S1 so that position 3 is either Manual flying (no GPS, just gyro) or to invoke failsafe, so that the PV behaves as if the controller has been turned off and initiates RTH.
  6. race3
    I like the idea of having the third S1 position invoke RTH. This way you don't have to worry about the transmitter reconnecting or taking time. However, if you initiate RTH with the switch... can you then just move it back to GPS or ATTI and take control again? I assume you can. Seems if the phantom is very far away and you can't view orientation, the RTH is a nice way to get it back towards you so you can continue flying.
  7. TisiRaptor
    That's what IOC is for, so there's no need to invoke RTH just to get it to fly back.
Similar Threads - Vid Tutorial DJI Forum Date
New Official DJI Mavic Tutorial Videos Released 29/09 Mavic Discussion Sep 28, 2016
How to format SD card with DJI Go App. (quick tutorial video) General Discussion Jul 24, 2016
Video or still tutorial for DJI GO app? Phantom 4 Discussion May 8, 2016
From DJI Log to graded Video Tutorial Photos and Video Feb 20, 2016
DJI hides tutorial videos? General Discussion Jan 10, 2014
