1080P Optimal FPS setting?
I need some input on what you guys think is the Optimal FPS settings for 1080P? I'm using 1080P vs 4K because I have an older Windows Vista PC and need the DJI Go video editor. I would prefer to edit on the PC but busted my piggy bank for the Phantom. I'm currently using 1080p 24fps with a shutter speed of 50. Would 30 or 60fps be better? Any suggestions would be appreciated.
depends on your final edit, If you want slow mo than you want your base fps to start the highest so you reduce it smoother. If you want to shoot a cinamatic smooth slower 23.97fps than choose that or 24 or 30 and then edit in your software to lower. Low light situations you want more FPS, higher light sources you can get away with lower fps
Reactions: beamerbuilder1
Thanks for the tips whoreable. That makes sense.
shimuafeni fredrik
