1080i/60 or 720p/60?
Discussion in 'Phantom 2 Vision + Discussion' started by sbarton, Aug 27, 2014.
  1. sbarton
    NJ
    I was using 1080p/30fps but it would blur when I pan. So I started using 1080i/60fps. A little better. Would 720p/60fps be better?
    I want to use as high res as possible due to the crappy camera making it look worse in lower res.
    -Scott
  2. RedRyderMedia
    The i in 1080i stands for interlaced, vs p which stands for progressive. The interlaced only scans every other line in a frame, so it is only half the resolution. It's a format used for old tube type TVs. You want progressive because it scans every line per frame and that's what flat screens and computer screens use.
    Your only real choice is 1080p at 30 fps or 720p at 60 fps. Try them both and see which you prefer. For your issue, I'm guessing you'll like 720p/60, but maybe you should just slow down your pans :)
  3. locoworks
    for slower pan help see here.
    viewtopic.php?f=27&t=23497&hilit=yaw
Similar Threads - 1080i 720p Forum Date
P4 HDMI on 1080i, ┬┐How? Phantom 4 Help Oct 7, 2016
Why not 1080i x 60fps? Phantom 2 Vision + Discussion Mar 13, 2015
Can't seem to record at 1080i at 60fps Phantom 2 Vision + Discussion Sep 26, 2014
Which phones will not sync with 1080i60 Phantom 2 Vision + Discussion Apr 26, 2014
Better 1080p that 1080i ? Phantom 2 Vision Discussion Dec 30, 2013
