+1Awilson18 said:This is why I bring mine home at 30%...
yali said:Lession Learned: RTH will stop working when battery hit 20 %
20% was thought to be enough for a RTH mission until I lost one in a river !
cahutch said:Makes me consider lowering my critical battery threshold to 12% just to prevent auto landing until there's no other choice.
I don't see a downside except that running the battery that low is not good for the battery longevity.
cahutch said:running the battery that low is not good for the battery longevity.
samd012 said:
Actually you are suppose to drain your battery down to 8% or below every 20 uses per page 10 of the manual.
yali said:I turned off my transmitter for the RTH when it is reaching 20 % and waited. when I realized it won't come back anymore, it was too late.
I could not see it, so, hadno idea what it was doing, so did not throttle it up. ... When I went to the Find My Phantom for its location, it's icon was in the middle of a river. I asked one standby and he said he saw it hovered above the water for a few seconds and slowly descended into water. never saw it anymore. It was only on its 4th flight : )
cahutch said:I changed my critical alarm threshold to the lowest possible value (12%) tonight in an effort to avoid this situation. I don't see a downside to it.
It's not much but it's an extra 3% before it starts to auto-land. More time is always better.
We'll if that's true (and I believe you) then why in the world would DJI limit the minimum value at 12%? The only logical reason for the "feature" is to give you a "gentle" landing before the battery dies completely and you fall out of the air. With 12-15% left, you still have time, and auto landing can't be any advantage at all until 2-5%DBS said:Don't know where you're getting that from but it's not really true... ... I fly mine down to 0% on a regular basis and they still show well above 10 volts after landing ...
Mori55 said:I would have used home lock , if I didn't see it very well. Tough lesson to learn.
samd012 said:cahutch said:Makes me consider lowering my critical battery threshold to 12% just to prevent auto landing until there's no other choice.
I always head straight home at the by the time the 30% alarm chimes in, have not pushed it much yet.
